Hmm...
I have noticed something weird with DVD2One.
I always set the size to 4300MB and do full movie.
Some movies come out soo well that I can't tell the difference from the original. Some movies (like Shanghai Knights) come out not so good (discoloration, weird water, some graininess) but still very much watchable. I don't see this in other 8Gig movies.
Just kinda weird and I'd like an explanation.
Also, I was wondering, any Mitsubishi Big Screen HDTV users out there? I am thinking of upgrading the old tube to one of those and I was wondering how your backups look.
Thanks!
Results 1 to 11 of 11
Just did a two-disk SVCD of Shanghai Knights with EasyVCD just for the hell of it.
I'm amazed at how nicely it came out. One nice thing about audio in an SVCD is that it tends to be "normalized" in the conversion process, and actually sounds better than many DVDs themselves (because of their wacked-out dynamic range --- high highs and low lows).
"I'm sick of paying for dinner and being served cowshit, while they give the bums eating out of the garbage my meal."
--- D. P. Smith -
It can depend on a couple of things.
Firstly, the length of the movie. In my experience anything much longer than 2 1/2 hours will start getting artifacts...mostly in high motion scenes...with re-compression (CCE, TMPGEnc etc.) you can get better quality.
Secondly, it depends on how it was encoded. Some movies are encoded to take up most of the disc and have bandwidth to spare...these compress quite well in my experience (note that studios are now doing this to some DVD's and are marketing them as "Superbit" DVD's)....other dvd's already use most of their bandwidth for various reasons...again, length of the movie plays a part but it may also be a high motion/action movie.
If it looks crap with DVD2One or DVD Shrink, try IC7...if it really looks bad you might be better off re-encodeing with CCE or TMPGEnc."Weekends don't count unless you spend them doing something completely pointless."
Bartman 8) -
Why do you use a lower size when doing a full copy? Isn't the default or normal size at 4472MB? At 4300MB, you're definitely losing some quality.Originally Posted by rvl123
But for me, I've always set it at 4464, which is the same size I use with DVD95Copy. I never had any problems with this size. -
Also... are you copying EXTRAS and whatnot, too? Of COURSE it's gonna look terrible, you're compressing 6GB (probably) of movie and 3GB of extras down to a TOTAL of 4.5GB. Yikes!
- Gurm -
If I want the full movie I usually take out the languages that I can't understand anyways. DVD2One has the option to take out soundtracks on a full dvd copy. Each 5.1 soundtrack is about 0.55 gigs and each dolby prologic soundtrack should save you an additional 0.25 gigs.
Which version of DVD2One are you using? Mine (ver. 1.1.1) doesn't let me remove any languages.Originally Posted by FT Shark
Also, on some DVD-Rs going over 4300 will make the movie stutter towards the end. Also, will 172 extra megs really make that much of a difference in the final product?
Thanks for all the replies. -
I'm using the DVD2One v1.1.3 however the latest is v1.2.3
Reguarding the stuttering at the end of the disk, that is a media problem. Cheap dvd's have major end of the disk burns. I used to have the same problems with Princo Brand. I switched to Ritek and haven't had a problem in over 500 burns. -
You should really upgrade your DVD2One to current version. There's been significant changes since v1.1.1.Which version of DVD2One are you using? Mine (ver. 1.1.1) doesn't let me remove any languages.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
