Hi,
I'm not sure if this is the right place (mods: if it's not can you move it for me)....Basically what I want to do is put vcd's that I've downloaded onto a dvd-r disk so that I can play them in my dvd player to view on my tv. I've tried a guide with (S)VCD2DVDMPG but had no luck because it converted the original vcd mpg to mpg which I can't burn in nero because it says it only accepts file types of .IFO .VOB and .BUP.
The vcd files I want to put on dvd-r is: trailer01.mpg, trailer02.mpg, etc.
The version I have of (S)VCD2DVDMPG is v1.1
And I have nero to burn them.
I wasn't sure weather to choose MPG - PS or MPG -ES either.
Can some one help?
Thanks,
Arther.![]()
AnonymousGuest
what Templateprofile use the comvert in TMPGEnc, did you use a VCD or DVD.
as far as burning a DVD from anything that comes out of TMPGEnc, you need to use a DVD Author program like TMPGEnc DVD Author, DVDit PE 2.5, etc, you can use compile anywhere from 6 to 10 VCD discs onto a DVD-Video. There are several guides on here that can explain 'how in detail' to get serveral VCD into DVD-Video format, they key trick is the uadio from the VCD has to be resampled from 44.1k to 48K, after that you do not have to reencode the video, just have it demuxed.
if you have a DVD Author program that hamdles AC3 audio, i have gotten 8 hours of VCD quality video with AC3 audio. but if you program does not accept AC3 then you are limited to about 4 hours.
all i have used for this proccess is
TMPGEnc to demux the video and the audio,
TMPGEnc to resample the audio to 48k
Goldwave to convert the MP2 to WAV
SoftEncode to convert WAV to AC3
DVDit PE 2.5 to compie everything into DVD-Video format
and Nero to burn the VIDEO_TS folder
https://www.videohelp.com/vcddvdr.htm -
Donate to crissyboy and receive the + version!!
This will do exactly what you are looking do do in a very painless way. it converts everything as well as authors for you allowing you to just copy the video_ts folder to nero as a data disc and then watch on your standalone dvd!!
this isn't an advertisement, its a testimonial!!
Enjoy -
you can do it by hand what svcd2dvdmpeg+ does but it will take you about 8 hours of working on the computer to put 8 vcd eps on a dvd+r and i know cause i did it this way a few times.
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 02:25 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 01:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
