I hope this is the right forum for this...I have searched high and low for good answers and found none...
What I'm trying to do is take my Monty Python set and put it on as FEW discs as possible...
So far, this is what I have come up with:
1. Rip each episode with DVDShrink (shrink to level 8 or 9-to make as small as possible...)
I can't really tell the difference between the original and the "shrunk??" version...
2. Demux the resulting VOBs with VOBEdit
3. Use the resulting *.m2v and *.ac3 files as assets in DVDLab and...
3a. Author DVD with DVDLab (works great!!!)...adding each new "MOVIE" as needed
4. Create new DVD folders
5. Burn to DVD-R with NERO
All above has worked GREAT so far, but what I want to know:
Is there a faster, better way to put episodes on fewer discs that I can't find? This is my first try at this (episodes), and I'm getting kind of frustrated with the time that it takes...
Any one have a better way?
I have succesfully placed 6 of the 45 episodes onto one disk using this method...
Essentially, all I want is to have as many of the episodes on one DVD as possible....
Any help or suggestions are greatly appreciated!
You could use DVDShrink to shrink the episodes you want to get them to fit on the disc, the ones that don't fit you could compress to still frames, then use menuedit to disable to button to select those episodes.
Which CPU is better and faster overall?
By Stealth3si in forum ComputerReplies: 14Last Post: 3rd Apr 2012, 08:48 -
Faster DVD Authoring
By TheLaserdisc in forum Authoring (DVD)Replies: 9Last Post: 14th Dec 2008, 20:41 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
How to burn faster
By Finfarin in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2007, 18:19 -
Audio faster than video
By WI2CA in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2007, 23:05
