ok i have only converted 3 DVD's to SVCD and i use the prog DVD2SVCD and
the 1st one i did it all went smooth but the last 2 i have done after im
all done converting and i go to split the large mpeg using this method
https://www.videohelp.com/bbmpegedit.htm and the 1st one like i said went
smooth but the last two it wouldnt work i would get a messege like this
video PTS (5351.83ms) underflow at pack 590 by 1.50ms
video DTS (5618.77ms) underflow at pack 638 by 54.57ms
video PTS (5652.13ms) underflow at pack 644 by 61.20ms
video DTS (5685.50ms) underflow at pack 648 by 54.50ms
video PTS (5718.87ms) underflow at pack 654 by 61.13ms
video DTS (5752.23ms) underflow at pack 657 by 47.77ms
video PTS (5785.60ms) underflow at pack 663 by 54.40ms
video DTS (5818.97ms) underflow at pack 665 by 34.37ms
video PTS (5852.33ms) underflow at pack 673 by 54.33ms
video DTS (5885.70ms) underflow at pack 677 by 47.63ms
so i looked at the log and i got this
Multiplexing: video and one audio stream
program stream type: SVCD with pulldown auto-detection
video file: c:\documents and settings\PIMP\my documents\PIMP STUFF
\charlies angels dvd2svcd.m2v
audio 1 file: c:\documents and settings\PIMP\my documen/PIMP STUFF
\charlies angels dvd2svcd.mp2
program file: temp.mpg
Multiplexing video and audio:
Scanning video stream for a sequence header and pulldown type ...
no pulldown detected ...
Scanning video stream for pictures ...
Found 135622 picture headers.
Video stream information
Stream length : 1530622449
Total time (seconds) : 4525
Sequence start : 15727
Sequence end : 0
No. Pictures : 135622
No. Groups : 15727
No. I Frames : 15727 avg. size 32245 bytes
No. P Frames : 60249 avg. size 13143 bytes
No. B Frames : 59646 avg. size 3883 bytes
No. D Frames : 0 avg. size 0 bytes
Horizontal size : 480
Vertical size : 480
Aspect ratio : 0.6735
Picture rate : 29.970 frames/sec
Bit rate : 315000 bytes/sec (2520000 bits/sec)
Computed avg rate : 338750 bytes/sec (2710000 bits/sec)
Computed max rate : 437400 bytes/sec (3499200 bits/sec)
Vbv buffer size : 114688 bytes
CSPF : 0
Scanning audio stream for access units information
Found 216513 audio frame headers.
MPEG audio stream information
Stream length : 158363752
Syncwords : 216513
Frames : 123722 size 731 bytes
Frames : 92791 size 732 bytes
Layer : 2
CRC checksums : yes
Bit rate : 28000 bytes/sec (224 kbit/sec)
Frequency : 44.1 kHz
Mode : 0 stereo
Mode extension : 0
Copyright bit : 0 no copyright
Original/Copy : 0 copy
Emphasis : 0 none
NOTE: Mux rate may be too low for data rate, watch for PTS/DTS
underflows.
Multiplexing information
Video stream data rate : 437400 bytes/sec (3499200 bits/sec)
Audio stream 1 data rate : 28000 bytes/sec (224000 bits/sec)
Total data rate : 348600 bytes/sec (2788800 bits/sec)
Multiplexing file temp00.mpg
it looks like the total bitrate is way to high but i dont see how thats
happening i use the CQ template i got from jakes website and i use like
min bitrate 300 and max bitrate 2520 and so im not sure how its messing
up here is every step i take in converting
1. Pop in dvd into my dvd rom
2. open up DVD2SVCD
3. click on rip and convert
4. when all the ripping and converting is done (EXCEPT THE TMPGenc part)
i start up TMPGEnc and put the dv2 and i think m2v files as my video and
audio
5. Load up the CQ template
6. Start converting
7. Coversion done
8. go here https://www.videohelp.com/bbmpegedit.htm
But like i said at step 8 is where its messing up so i have to split the
file using this program
DVtool.ttp://www.musclesoft.de/combatman/sindex.html and its a real pain
to figure out where to cut it and all that crap plus i guess im getting
rips that are way out of bitrate so i wont put them in newsgroups with
above standard bitrates
Can someone please let me know where im going wrong ?
also after i use DVD2SVCD what should the video file and audio file be?
TIA for any help
im ready to rip a DVD but i wanna get it right this time with correct
bitrate and all that
DVD2SVCD will split the files for you and create an image so you can burn
it straight to disc with an authoring program like nero.....
I am not sure you are using DVD2SVCD correctly ...it will doeverything for you....Right from the start ..to finish
Have you read the guides on how to use it by the sounds of it you doing it all wrong. Sorry to say this to youHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
well then it has already split the files for you. In the directories there are files (depending upon how many splits there are ) called bin and cue.
If you notice the bin is about 800 mb and the cue is only a few kb. These files contain the movie already packaged up in svcd format. Go to Nero and go file burn image. You will notice only the cue file appear. That is fine click on it and burn it ready for your viewing pleasure. The cue file points to the bin file. so you see you don't have to cut anything. all you have to do is burn the bin/cue files.How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
But what i do is rip everything and do all the converting (Except what TMPGEnc needs to do)
When i do a DVD2SVCD i dont always wanna do the whole converting at once i wanna do everything DVD2SVCD needs to do then later i do the converting with TMPGEnc
Are the settings on that page i posted good? -
see if this post helps:
https://www.videohelp.com/forum/viewtopic.php?t=111238&highlight=pts+underflow----------------------
jbcalg
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48
