i'm converting PAL SVCD mpeg2 files to NTSC DVD-R.. I'm confused.. i ended up with 1 m2v file (from TMPG Plus) and 2 .wav files using Goldwave (the original files were in bin/cue, from which i ripped mpeg2 svcd files using ISObuster--->gave me 2 separate mpeg2 files).
Do i need to join the 2 wav files, then import into Maestro or IFOedit.95?? I ask b/c on my 1st attempt, i let Virtualdub create 1 large .wav audio file, with which i tried Maestro and IFOedit to reauthor.. here's what happened:
in Maestro, the video came out fine, but there was no audio (maybe Maestro does not support wav files.. ??)
in IFOedit.95, the audio came out ok, but the video was sped up.. ??
i'm stuck.. right now, i've got 1 m2v file that TMPG created and 2 .wav audio files that Goldwave created (48000 sample).. please advise.. thanks.
Results 1 to 1 of 1
2 small questions about authoring with IFOEDIT
By i_j_2009 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 11:15 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 06:54 -
ifoedit/sony vegas-->sound problems
By carock in forum Newbie / General discussionsReplies: 3Last Post: 5th Nov 2008, 11:28 -
Usinf IFOEdit to correct an error in authoring
By netmask56 in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 23:30 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 16:37
