  1. I have a little problem.Does anyone know where I can find VCD subs and what format should they be in.
    When I later burn them with NERO, Which folder shall I put them in?
    ESCH
    Feb 2001
    Berlin, Germany
    Don't know, where you can find subtitles. But I know, you can not simply put them in any folder of the VCD.
    There are two ways. Use I-Author to multiplex video, audio and subs. Here you need an I-Author OGT.txt, that refers to .bmp subs.
    Or you may find .srt or .ssa files, that you can add to the movie using Avery Lee's subtitler. Sure then you have to reencode. Please have a look at the FAQ.
  3. Thanks for the help.
