I know this is a very stupid question but I ask anyway since I have tried hard but could not get it to work right.
I created DVD content using DVD authoring software. The result is a VIDEO_TS folder with .IFO, .BUP and .VOB in it. If I burn that to DVD, everything work fine.
My main question:
How do I tell PowerDVD to play the movie in this folder such that it plays just like on a stand alone DVD player ? i.e. with menu, with NEXT to play next chapter and so on ?
Please give detailed instructions if there is a way to do it.
Thank you
ktnwin - PATIENCE
Go to GUIDES on this site http://www.dvdrhelp.com
Type in PowerDVD
Guide is "How to play DVD from HD" -
Just right click on the file icon then select "open DVD files on hard drive" and select the VIDEO_TS.IFO file.
Note this will require PowerDVD 4.0 or above (3.0 could not open files on hard drive).
"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
It seems that I have the same problem with PowerDVD. When I select the VIDEO_TS.IFO file - it cycles through all the menus quickly and then jumps to the first title and starts playing from there. How/what do I load into PowerDVD in order to be able to navigate the menu(s) and select what I want to watch (like extras, deleted scenes, trailers, etc.)?
What happens when you select either the Title or Root menu option after it's started playing your movie? Does it still recycle quickly and go back to the movie? And what version of PowerDVD, what OS?
thanks for all the helps. I will give it a try.
Feeling pretty stupid for not knowing how to do this after using PowerDVD for 2 years now.ktnwin - PATIENCE
PowerDVD won´t play it !
By JGT in forum Blu-ray RippingReplies: 9Last Post: 3rd Feb 2010, 15:37 -
PowerDVD 7.3 can't play HDDVD on win xp ?
By JGT in forum Software PlayingReplies: 1Last Post: 3rd Feb 2010, 05:54 -
Powerdvd 9 play BD from Hard Disk
By giosa in forum Software PlayingReplies: 14Last Post: 7th Nov 2009, 12:42 -
Updated PowerDVD wont play HDDVD backups
By aye29 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 04:58 -
PowerDVD XP 4.0 Won't Play in Updated WinXP
By SLK001 in forum Software PlayingReplies: 4Last Post: 14th Aug 2007, 11:05
