Results 1 to 9 of 9
  1. i have 3 .avi movies and i basically wanna burn em on dvd.
    Problems:
    1)the first .avi movie and 3rd .avi have an error or something. when it reaches a frame it just messes up. And i usually have to close the player and reload the .avi and just manually skip over it ( error lasts around 5 seconds or less) then its just the rest of the movie.
    So im thinking maybe an .avi editor that will let me crop those 5 seconds and wont hurt the quality of the movie.
    2)AC3- i got the filters and turned it in to wav file, then i converted the .avi to mpeg with the wav and its out of sync. Also because of the error in the movie. There is no film in the mpeg after the error so i really need to edit the .avi without hurting quality and i need good instructions/opinions on how to get the sound in sync.
    Can dvd players play ac3 or is it requirted to turn it in to .wav and .mp3? if it is required tell me wat i did wrong or something.
    I used goldwave and turned it in to .wav on 48000hz it plays fine its just out of sync.
    Help will be greatly appreciated.
  2. First try useing a program called DIVFIX on your avi.
    To get it just do a search for it under that name.
    When you have it installed open your avi in it and run the rebuild avi index option/ keep original file.
    Depending on how many errors there is it might be able to repair them.
    If not run the program again on the ORIGINAL not the divfix repair file produced on the first attempt (that just wants deleting)
    this time however tick the box that says REMOVE BAD PARTS.
    Even if this a good few frames it won't affect the watching of the movie and often cures the out of sync problem.
    Jan 2003
    Nassau, Bahamas
    have you tried scanning for bad frames using virtualdub..... heres the link..... https://www.videohelp.com/forum/userguides/142555.php.. holla back...cause it just sounds as if the file has a freeze in it
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  4. awesome, there were 38 bad frames and deleted em...now the clip runs smooth.
    Now i need answers on audio. Can dvd players play ac3 or do i need to change it to mp3 or wav. and if i need to change it...which one is better.
    Also wat program and bitrates to make the video sync.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Yes, dvd audio can be ac3. Pick an avi to dvd guide guide from the "Guides" section and go.
  6. Ok the .avi have ac3 so wat guide do i use. I tried using one of the guides and TMPG gave me an error that it couldnt open it after i set all the settings and tried to make it mpeg2 that it coudlnt open it or that it was unsupported. I am a beginner and those guides look a little more for advanced...i have fixed the .avi's but now the problem is....wats next. No more guides please i spend an hour or more on the guide.
    Wat program and how do i keep the ac3 audio or dlasfj ;al please need help. HOW DO I Make it an mpeg2 without converting the ac3 to wav or mp3 is basically my question i suppose. and remember wat board ur in...the newbie one
