  1. is it possible to put vob files directly through dvd shrink or clone dvd cos im having great difficulty doing this'
    thanks for your help
    May 2003
    NO u cannot load the vob directly u must open the entire folder that the vobs are in and the folder must contain the .ifo files for the vob sets
  3. Member Devanshu's Avatar
    May 2003
    Nope...you can try but you will not succeed. You need .ifo's also.
    Dec 2002
    Texas USA
    Make new IFOs. IFO Edit, I hear, but I never use it.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  5. well what i did was was rip 3 movies and put them on dvd lab, made a menu for them and copied the full thing to a folder.
    would it now be possible to put this through shrink or clone i thought it would be sraight forward but it aint letting me do this.
    thanks for your help.
