Hi,
I was trying to test my DVD read speed and the fastest I could see (via smarripper and dvd decrypter) was about 4x eventhough the HP300i can support up to 8x (supposedly). I tried Nero CD speed utility and it also reported about 4x for the DVD. I check my IDE controller and it setup for UDMA. I run windows 2000.
Is there anyother options/switches I need to do to get the 8x read....
Thanks for any help!!!
Results 1 to 1 of 1
Hi-8 tapes need to transfer to DVD
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Apr 2011, 03:42 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
How do I transfer data into dvd.
By millyvanilly in forum Authoring (DVD)Replies: 8Last Post: 24th Jan 2009, 21:34 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48
