Iam looking for the best way to get a divx file on a dvd..is the best way useing ffmpeg and dvdstudio pro, does anybody a good manual/guide to do this...please help tnx a lot!!!!!!
Results 1 to 10 of 10
its been well covered in the forum somewhere. try a forum search
one that comes up is
https://www.videohelp.com/forum/viewtopic.php?t=158937&highlight=divx+dvd
also
https://www.videohelp.com/forum/viewtopic.php?t=163153&highlight=divx+dvd
enjoy -
or ge a standalone dvd player that plays divx burned onto cd's. Thats what I have been doing. It also works for a data DVD, so no need for splitting the movie.
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
yea, but how much does a dvd player that plays divx movies cost. Unless the prices has come down a lot since I looked, its a pretty $$
they are between 150-200. I bough one on ebay, i think it was 176. They work perfectly. I especially like being able to choose a movie from a cd or dvd tha divx instead of having to watch the whole disc.
Q"Good Luck 007"
In an effort to answer the QUESTION here, the best way is to run your .avi file through Divx Doctor [http://doctor.3ivx.com] and tell it to NOT make a standalone movie. This will get you a .MOV file that Quicktime will play where the audio is just fine.
From Quicktime, Export to MPEG2.
This will create demuxed mpeg2 streams ready for DVDSP.
You can then convert the audio to AC-3 if you want or just use the .AIF format.
As for standalone divx players, i have a handful of them and they all work great. Divx 3.11 included. -
I am useing, ffmpeg to make a m2v file, and than open it in dvsp, i don't see why i woulde need quicktime...??
quicktime is the most straight-forward way. If you wanted to customize your encoding process, FFMPEGX would no doubt be the way to go. IMHO, however, for this case, I would recommend just using Quicktime.
God knows I would if I had a G4. Damn thing won't run without Altivec. CRAP!
=P
Good luck -
Yea it works nicely like kamikaze said. If you have mpeg2 export option just do that.Originally Posted by kamikaze
kamikaze - think of how it will work on the g5's!!
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
