I have an old notebook that has a defective hard drive that needs to be replaced. I've got the new drive and I will need to reinstall 98SE, but this thing only has a floppy for input. It has a EPP capable parallel port, and also two PCMCIA slots.
My problem: How do I get the OS installed (and using floppies is NOT an option!)?
I can install a network card and use the CD-ROM on another computer, but can 98 be installed like this? Also, I can buy a parallel CD-ROM just for the installation of the software.
Has anyone done any of this before?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
SLK,
If you have another pc (ie a desktop), you can purchase, (for about $5) and IDE adapter for the notebook drive which converts it to the regular 40-pin set up. Just temporarily install it, the notebook hard drive with adapter connected, in the PC, format it bootable and copy your cab files, drivers, etc. over.
When you plug it back into the laptop, it'll boot it the c:\ prompt then just run setup from your cabs location.
That's generalized but once you get the adapter, the rest is just like installing a hard drive in a pc.
Good luck."All are lunatics, but he who can analyze his delusion is called a philosopher."
- Ambrose Bierce
"The power of accurate observation is frequently called cynicism by those who don't have it."
- George Bernard Shaw -
Here are three links, two in UK, one in US as examples:
http://www.mini-itx.com/store/default.asp?c=9
http://www.novatech.co.uk/novatech/specpage.html?BEL-F2N511
http://www.mycableshop.com/sku/ST-BRACKET25.htm"All are lunatics, but he who can analyze his delusion is called a philosopher."
- Ambrose Bierce
Thanks... I didn't know the adapters were that cheap.
I ordered one for $4.95, received a $6.00 off coupon and shipping was $5.95. They wouldn't rebate me the difference so I ended up paying $5.95 for a free item.
I use this adapter in my firewire or USB2.0 cage to put files on the 2.5" drive and it works like a champ. Ghost also includes USB drivers in DOS mode if you want to make an image of the laptop after your rebuild it, that way you've got insurance against mistakes.
Good luck!"All are lunatics, but he who can analyze his delusion is called a philosopher."
- Ambrose Bierce
I covered all my bases. I ordered that adapter for $4.95, I got a PCMCIA 10/100 NIC for $18.00, and I ordered a parallel port CD/RW for $55.00. These belong to my sister and her daughter, so I thought that having a CD burner (to share between them) would be a good idea. Anyway, my brother-in-law said that he would pay for all of this stuff.
I think that the easiest way to do this is with the external CD-ROM. That way, I don't have to tell open one of my systems to set up the disk.ICBM target coordinates:
will not install
By ka3wjz in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 30th Jun 2009, 21:07 -
install software
By member2055 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2009, 09:41 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 16:37 -
install
By Brasilman in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2007, 09:17
