Well I have never had problems capturing things to vcd after fiddling with settings and what not, but no matter what I seem to do i can't get things to fit on a dvd-r. I have been trying to captur the 90210 commercial pilot and everytime I do it using the standard dvd setting its like 4.7 gig or higher and the video is only 1.5 hours. Any help woul dbe appreciated. Thanks!
Try using custom settings in MMC and find out what bitrate to use with a bitrate calculator. You can find one in the tools section. (the dvdrhelp one is the easiest to use).
just author the dvd and then run it through dvdshrink or dvd2one. they will transcode to the correct file size is 15 minutes. don't wast time trying to fiddle with your capture settings.
capturing vhs avi too big
By adhawk76 in forum Capturing and VCRReplies: 26Last Post: 5th Mar 2010, 14:58 -
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11
