Hi!!!
Just saw the same problem on another post, but no answer on how to fix it?? When I start the program, it just says common language runtime debugging services, and application has generated an exeption that could not be handled , process id=0xb1c (2844), Thread id=0xb24 (2852)
Any possible quickfixes??? I am running xp pro in german, and have an amd 2000+ with 1 gig ram (ddr 266)
any help would be greatly appreciated!!!!
Randy
grey.zone(at)angelfire.com
Guest
This is due to a wacky .Net floating point error. It is totally random in who it affects. Make sure you have the latest build. Can you use another PC?
Failing that the only way I have been able to fix this for the other 2 or 3 affected users is to locate the line of code which triggers the FP error by trying lots of custom builds. It is easier to do this over MSN Messenger. Let me know if you want to try.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Guest
Maybe its because my win xp is on G
(dont ask)
Anyway, installed your excellent program on my laptop (2500+), and it runs just fine so far... a bit of pushing stuff back and forth over the network doesnt bother me..
Thanks!!!!!! -
{S7} QuicksilverGuest
This may a reason as well.
I too have gotten the common language error. What I did to "maybe" fix this was uninstall the SVCD2DVDMPG (non plus version) and reinstall the .Net service then reinstall the SVCD2DVDMPG. Afterwards, the program worked like a charm. Admittedly I have not done this numerous times nor have I tried it on multiple PC's but, experience has shown me that this may be the reason for the "whaky" behavior of the program.
Oh and Chrissyboy, you have great customer service and lots of patience. Top that with great tutorials, you should be a millionaire in no time; just remember me and send some my way
Thanks for the kind words - but I won't be giving up my day job!great customer service and lots of patience. Top that with great tutorials, you should be a millionaire in no timeSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
On startup, keep getting a Common Language Runtime Debugging Services alert
By Carl III in forum ComputerReplies: 1Last Post: 18th May 2010, 17:04 -
Runtime error
By The Monarch in forum ComputerReplies: 4Last Post: 28th Feb 2010, 03:42 -
runtime error
By ram16 in forum Newbie / General discussionsReplies: 9Last Post: 20th Dec 2008, 23:04 -
Runtime error
By Illusionist in forum ComputerReplies: 7Last Post: 13th Jul 2008, 00:01 -
Common Language Runtime error
By scrtagt69 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 2nd Jul 2007, 03:42
