Are they BIG difference between these 3 chipsets for capture from VHS?
Are the quality noticeable??
Please give me some ideas
thanks
ie. I compare capturing from VHS with AIW ( rage theatre ) or newer AIW ( theatre 200 ) and TV Wonder ( BT848 ). No gaming or 3D is involve, just the capturing capablity is important
thanks
I tried BT848 and Rage Theatre. Definitly is Rage Theatre better capture chip, and difference is visible when you use the same codec (preferably huffy). BT848 produces more noice and can't capture on the the same ate and format as Rage (max. 720 x 756, 25 fps).
Regards
Ati theatre 750 vs theatre 650
By smengy in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2013, 21:10 -
RAGE PC ending disappointment **Spoilers**
By retroborg in forum Off topicReplies: 1Last Post: 2nd Jan 2012, 09:06 -
PC to Home Theatre
By paulag in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2010, 07:20 -
Resolution Test - BT878 - ATI Rage Theatre - Philips SAA7130
By BrainStorm69 in forum Capturing and VCRReplies: 3Last Post: 23rd Mar 2010, 06:10 -
Home Theatre 'Lite'
By Seeker47 in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2009, 13:39
