i have a film its an avi but when i encode it i get no sound i have checked it with gspot an was told that i have 2 codec so i extracted the sound with goldwave but then i dont get a sound file but an osloskop file please help![]()
If you get a sound file with Gold Wave, why not save it as a wave file and mux it with the new sound file as audio input.
Hello. -
Save out the audio use the file name audio.ac3 once it has finished you will have a file audio.ac3.wav, remove the wav file extension. Open it in headac3he convert it and then use it as the audio source file in tmpgenc.
Remote needed
By IMREW in forum ComputerReplies: 3Last Post: 27th Mar 2010, 08:19 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
some help with ripbot needed
By davebarnes2009 in forum Blu-ray RippingReplies: 6Last Post: 12th Jul 2009, 15:07 -
Help with PC to HDTV Needed
By denzlite in forum DVB / IPTVReplies: 12Last Post: 13th Jan 2009, 16:34 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
