How do you combine different VOBs from different DVDs onto a single DVD? I believe this is an authoring, not a ripping question.
Specifically, suppose you already ripped various small titles from separate DVDs each into its own directory. Then each directory would have a VIDEO_TS.IFO, VTS_01_0.IFO, and VTS_01_1.VOB file. Since all these titles are small in size there is only 1 VOB in each directory, so several titles could fit on a DVD-5.
What I want to know is how to take each of these directories and combine them into a DVD with all of them as separate titles selectable from the player's root menu OR I would be equally happy combining them into 1 title (merging the VOBs) with a single chapter stop between each.
I searched this web site and various posts, but none of them described how to author a DVD like this in a way I could understand. I know it's not as simple as renaming the files. Somehow I have to make the main VIDEO_TS.IFO point to the new IFOs and VOBs. I'm hoping there is an easy solution someone can point me to which does not require a full blown authoring package. Thanks.
Results 1 to 9 of 9
Have a look at http://ifoedit.wh.fr0zen.com/joinclip.html I am about to doing something like what you've just mention.
It can be done. I'd love to help, but don't have time right now. The response would take a while, and I'd need to double-check a few things.
While I'm not much of a help immediately, rest assured what you desire is possible. I thought some reassurance would be better than nothing.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Not complicated at all. Get TMPGenc Author and import the DVD files. You can have menu options including chapter breaks with motion thumbnails. It works great! There are a lot of guides and its the easiest way to make a DVD from multiple vobs.
"Only Users Lose Drugs" -
https://www.videohelp.com/forum/viewtopic.php?t=167382&start=0&postdays=0&postorder=asc&highlight=
in your case you could rename your 3rd dvd files
vts_03_1 ifo bup vobs
your 4th
vts_04_1 ifo bup vobs etc
and dvd fab or dvd toolbox will correct everthing for u
you would just have to acces each part through the titles of your dvd player -
Ronaldus
u can only have one video_ts ifo file (not different ones in their own directory)
as that control the whole dvd -
Originally Posted by AndThenSome
Kenmo. Yeah, its a great proggie but I wish there were more styles to choose from.
The program directory has .tme files but I dont know if there are any out there. I kinda did some hunting on the web to see if anyone had any to download and use with Author but I havent had any luck. You heard about any?"Only Users Lose Drugs"
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 16:22 -
What/How to combine DVDs
By fordgrl99 in forum Newbie / General discussionsReplies: 1Last Post: 26th Oct 2011, 11:16 -
How do I combine DVDs?
By sldvd in forum Newbie / General discussionsReplies: 2Last Post: 31st Mar 2010, 22:38 -
Combine DVDs
By mike202513x in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2010, 12:56 -
how to combine dvds without using dvdremakepro
By Onceler2 in forum DVD RippingReplies: 3Last Post: 3rd Mar 2008, 13:58
