I was in CompUSA looking for some blank dvd-r discs and came across a 50 pack spindle of Memorex 4.7GB DVD-R discs... the packaging said they were "VERSION 2.0" DVD-R discs...
what is "VERSION 2.0" referring to? I've never seen that before.
"First there was the DVD-R Version 1.0 that provided a 3.95 Gb disc using a 635 nm drive. Later the 4.7 Gb disc was released as Version 1.9 using the 635 nm technology. Now DVD-R Version 2.0 media and drives are available. Version 2.0 media is 4.7 Gb Authoring DVD-R and can only be written on Version 2.0 drives. (1.9 and 1.0 media can be written in 2.0 drives as well)." - Taken from http://simplythebest.net/info/dvd.html
Visit me at www.virtualaftershock.com/ for all your Custom DVD cover needs. -
icoty...
thanks so much... that clears it up.. saves me from returning the discs, since they wouldn"t have worked with my burner. -
how does one go about finding out what version drive they have as far as disk version?Originally Posted by icoty
I purchased one type of dvd-r media that just wouldnt work at all! maybe it was a disk version thing.
just wondering.
i have toshiba SD-R5002 dvd burner if you know where to get the version type off it id appreciate it. -
According to http://www.cwol.com/dvd-burners/toshiba-sd-r5002.htm , it seems that your drive is able to write to version 2.0 media. I would think that it should be backward compatible with version 1.0 media since it is version 2.0 compatible but the site doesn't mention version 1.0 compatiblity with the Toshiba SD-R5002.
Thanks for the info
it must be able to burn 1.0 disks because i know at one point i had some of those
thanks
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48 -
Where to ger Powerbook5,3 (version 1.1) restore discs?
By Denvers Dawgs in forum MacReplies: 3Last Post: 15th Apr 2011, 10:08 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
