  1. Member Gritz's Avatar
    Feb 2003
    I've read about Epson Printers being able to print directly to cd, but the reviews indicate that they smear easily. I was wondering why it would not be possible to spray the printed ink with some of the clear finishes that you see in some of the craft stores?? Seems like if it only added minimal weight and it was somewhat heat resistant it would work fine. I'm thinking you could pop it over the post of an empty media box and mask the edging if underspray was a concern. Anyone try this yet?
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
  2. Haven't tried that yet however I also don't have a smear problem with the few discs I have printed with my Epson 900.
    Feb 2003
    For more information concerning protecting the printed surface of printable media see my post on the forum topic listed below.
    https://www.videohelp.com/forum/viewtopic.php?t=167391&highlight=
  4. Member Gritz's Avatar
    Feb 2003
    Thanks guys .... appreciate the info and redirect, which answers my concerns.
