Results 1 to 9 of 9
  1. how do i get rid of "Tools for internet explorer" i'd really like my 23 mb back.
  2. Click on the change/remove button
  3. that isnt working and apparently is produced by some company called traffic syndicate. excuse me. who can i contact to threaten this "traffic syndicate"?
  4. By the name of the company, it sounds like some type of spyware. I would first try Ad-aware.
    Also, does the remove actually remove the program? It may just not remove the program from the registry. If this is the case, I can show you how to remove it from your registry. But keep in mind that this would only remove it from the list in the Add/Remove window, it would not actually unistall the program.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  5. If all else fails
    Boot from a floppy
    type "format C:"
    JUST KIDDING ! ! !
    Originally Posted by jagabo
  6. Originally Posted by stiltman
    If all else fails
    Boot from a floppy
    type "format C:"
    You know better than that stiltman. You never give away our secrets!!!
  7. I've had that before and got rid of it with Ad Aware but it still left the entry in the Add/Remove menu.
    I just got rid of that with TweakUI.
    Their uninstall program that they offer (Traffic Syndicate) seems bogus to me as I tried multiple times without success.
    Dec 2002
    Dallas, TX
    If all else fails
    Boot from a floppy
    type "format C:"
    JUST KIDDING ! ! !
    Try format c: /q
  9. ad aware works. traffic syndicate should have been filed suit against at least once for this.
