I bought [yes bought with my own money,legally] a dvd with the wrong region ,,,ugh...[an import obviously]...how the heck do I change it so i can watch it on my DVD player
I have the files ripped and am trying to figure it out
the easiest would be if you could make your dvd player region free...
however, if you can't, then when you're ripping the DVD using dvddecryptor, there's an option for it to remove RC and RCE region protections...
after that, the files will be region free and you can encode/convert/burn them to whatever you want. -
the files are pdi...i dont know if that makes any difference, I thought that would have had something to have to do with why it doesnt work in a regular dvd player
I know that Pinnacle's Instant Copy uses .pdi to designate an DVD image on the hard drive (Pinnacle Disk Image file?). Perhaps that's what you have. If so then you could use Instant Copy to burn the pdi to a standard DVD.
Look for DVD player that can change from region 1 to all regions
By plk1758 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Feb 2010, 10:27 -
Code to allow DVD use on all regions
By eaglet in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2009, 11:04 -
How do I change audio codec on an already burned dvd/video converted file?
By klobb in forum AudioReplies: 5Last Post: 31st Dec 2007, 05:03 -
Data DVD Regions?
By cyberdrugi in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2007, 14:06 -
How to change regions on a DVD or TV?
By SnowStormWolf in forum ProgrammingReplies: 1Last Post: 8th Jul 2007, 17:11
