Hello,
I would like to know if anyone could help me, how do I burn a disc using Pinnacle studio 8, I made an DVD image with studio 8, the program said that I could make a DVD using studio 8 from the image. I have recordnow DX whice came with my burner (DRU-510A Sony) but got two bad disc trying to use recordnow, so I wouls like to use studio 8 if it can be done.
Thanks in advance.
Results 1 to 14 of 14
XXL
To burn a disc using Studio 8 just open the project > click make movie tab > settings > select burn from disc image in the burn options box. I'm using Studio 8.5, so that says burn from previously created disc content instead. Maybe that will work, if not try another program. When I have an image I use DVD Decrypter to burn it, not Studio. Also, if you've been getting bad copies then test on a RW disc first.
Ahhh my first post on this board
And it only took 13 days after you signed up. Waiting for the opportune moment?Originally Posted by CPimaging
I believe you could also just burn it straight from your project instead of making an image first. I only use Studio 8 for editing though, no burning."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
You can burn it either way. Part of Studio 8 is being able to author and burn in one step. Re-open your image file in Studio and burn to disk. You can use a +/- RW first if you like, then use Record now DX to make a copy to +/-R for your finished disk.
You can also go here: http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&SectionID=143&lng=1&Produ...DocTypesID=181Geronimo -
Thanks for the help, and that's what funny I did test with an RW (TDK -RW) and the test copy was fine (burn with recordnow) but when I tryed to burn on -R (verbatem -R) with recordnow got error.
XXL -
Are you doing a disk copy with Record Now? Use the wizard and choose "Make a Exact Copy".Thanks for the help, and that's what funny I did test with an RW (TDK -RW) and the test copy was fine (burn with recordnow) but when I tryed to burn on -R (verbatem -R) with recordnow got error.Geronimo
If you are getting the burn error on a different type of disk, it may be the disk and not the program causing the error.
I think he's trying to burn the image...incorrectly instead of making a exact copy of the -RW disk.Geronimo -
The way I understand it is he burned an image to -RW and it worked, then he tried to burn the same image to a -R and it did not. It sounds like the -R disks may be faulty. Am I misunderstanding something here?Originally Posted by Redd"A beginning is the time for taking the most delicate care that the balances are correct."
LOL...One of us is bound to get it...or maybe not! >;-}Am I misunderstanding something here?Geronimo
Yes it did, I was out of town.Originally Posted by Solarjetman
Thanks for all the help, it had to be the verbatem disc that was bad because I burn four copy last night with recordnow and all was OK
XXL -
I am happy you got it working and it was only bad disks and not a drive. Much cheeper than replacing a driveOriginally Posted by tyoneXXl
Sugestion. Do not burn with PS8. It can do it but it is not it's primary goal. Use burning software. I use Nero in combination with PS8.
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Pinnacle Studio 8
By Victri in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2007, 05:18 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 04:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53 -
pinnacle studio 11
By serega in forum Latest Video NewsReplies: 14Last Post: 13th Sep 2007, 19:14 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 23:56
