From a backup copy can i just copy disk to disk ie: source disk in dvd drive and destination disk in dvd writer will the copy work or do I have to transfer files to harddrive and burn from there
thanks
If your are talking already burned DVD's yes you can. I really would not recommend copying on the fly....because any hiccup in your source drive will create a coaster. My prefered method is creating an ISO then writing that ISO to DVD.
I used to do COPY on the fly to save time ...but somethimes a thing as small as a fingerprint will cause a read error and you are stuck with a coaster.
It takes a little longer but if i get an error creating an ISO I just clean the DVD and try again. -
Can I not just drag the files from my dvd disk drive to my hardrive
and then burn the VIDEO_TS folder ? -
Yes you can. Create a folder on the desktop, drag to it, burn from it, then delete it -- very simple.Can I not just drag the files from my dvd disk drive to my hardrive and then burn the VIDEO_TS folder ?
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
how to copy from DVD recorder to external disk or blue-ray writer?
By uwacm@gmx.de in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2011, 05:14 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
How to copy Philips 3590H hard disk files to a computer
By themastan in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Sep 2010, 06:15 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35
