Ok ive having problems. I use SVCD2MPG+ and have it rip and convert from a bin file. I select Author DVD folders. I use Primo DVD to burn the created VIDEO_TS folder. When I try playing the DVD, my DVD player tells me not an NTSC disc. I have this problem on 3 out of 4 dvd players ive tried it on. I also have made more than one DVD this way and have the same results. Am I missing a step or a setting??? Any help appreciated..
rodan1967Guest
only thing i can think of is that you origional mpeg wasn't NTSC, did you check that?
other thing that could be is that the origional mpeg was NTSC Film and that format isn't available for DVD mpeg2 so maybe the player only likes VCD-DVD or SVCD-DVD with NTSC mpegs.
Yf
