I have about 30 VHS Home Video tapes and I'de like to convert them to DVDs. And some videos I'de also would like to convert to wmv(windows media) format so I can stream them from my web server. I will prolly would not be doing much editing, but I'de like to have the ability to do so.
Right now I have a entry-level Dell machine P4 1.6ghz, 40gig drive, 512mb ram.
What Hardware, Software do I need. I'de like to spend about $1000-1500 in total.
1) I'de like to spend under $300-$500 for a video capture card.
2) I'de like to buy a DVD-R drive, fast and reliable.
3) Whats the best software to edit these in, is it Adobe Premiere.
4) Should I buy a new vcr, my kind of sucks, which one?
5) Do I need to buy a bigger Hard Drive (40gb 7200rpm), more memory(512mb)?
6) Should I consider buying something else?
I'de like to convert them in the best quality possible and also fast.
Please recommend me what stuff to get. Thanks in advance.
1) I use an ATI AIW 8500. This is designed mainly for MPEG 2 capture and it sounds like you want AVI to edit so better get someone elses opinion.
2) A pioneer A05 or A06 I have an A05 and its very reliable.
3) Adobe Premiere is probably the best, but is expensive.
4) Maybe get a S-VHS and maybe a Time-Base Corrector.
5) Bigger hard-drive 7,200rpm as big as you can afford (especially for AVIs). 512MB of RAM is fine.
6) Nothing else I can think of.
What is the best format to convert VHS-C tapes to?
By Theresa in forum Newbie / General discussionsReplies: 16Last Post: 15th Jun 2014, 11:26 -
Convert VHS or U-matic tapes to any digital format
By predatorz6 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2012, 08:36 -
trying to convert old vhs tapes to dvd, used sony direct to dvd, not good
By hygieneboy in forum Capturing and VCRReplies: 27Last Post: 4th May 2009, 14:57 -
Can VirtualDub record VHS tapes to AVI format?
By gregnovella in forum Capturing and VCRReplies: 4Last Post: 29th Apr 2009, 00:37 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 14:51
