What format does a DV Mini Cam capture to your Hard drive as ? DV format and then how can i convert it to an AVI format
Actually, DV is an AVI format. To convert it to another AVI format, I would try Video Studio 6.
Hello. -
What is your final plan?Originally Posted by andylouie
What are you trying to output to?
vcd, dvd?
mpeg1, mpeg2?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
If your use Video Studio (trial is free for 30 days), you can capture in DV, edit, add chapters, and burn to DVD.
Hello. -
Then I would suggest something like Pinnacle Studio 8.5.Originally Posted by andylouie
I capture DV, edit, add transitions etc and save as an avi (using the same codec I did to capture therefore no loss in quality).
I do this as I prefer TMPGEnc for encoding but if you choose to Pinnacle will do everything, including output your VIDEO_TS folders I believe (although I haven't tried this yet).
You'll get a lot of people critising Studio but I lovge it (for DV only, it's horrendous for anaolgue capture!).
One last thing...
...if you haveno need for editing (other than trimming perhaps) and you have an encoder already you don't need to save to avi.
You can encode your captured DV directly to mpeg2.
As I said, I love TMPGEnc (which is free for 30 days for mpeg2).
Very Basic--> What format to work with Final Cut with my HD cam.
By Mcjuicypants in forum EditingReplies: 0Last Post: 5th Mar 2011, 21:55 -
Capturing Web Cam Through Adobe Flash In Browser
By johnsmith153 in forum Video Streaming DownloadingReplies: 0Last Post: 11th Jun 2010, 18:35 -
curious dvr-ms format and conversion
By todds1 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2009, 05:38 -
Pioneer DVR-560HX & random problems with CAM module + video adjust menu
By vincent_scot in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Mar 2009, 12:03 -
Capturing from MiniDV Cam & Audio simultaneously...
By gtrgriff3 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Aug 2008, 19:56
