I can make DVD's from SVCDs/CVDs just fine, I find IFOedit slow, but it works.
What I want to know is, whats an easy way to have 2 movies on 1 DVD and be able to easily select movie 1 or 2. I know how to put 2 movies on the DVD, and I like to have chapter points every 5 minutes. So doing the second movie as a chapter point is kinda something Id like to avoid. I'm thinking about using multiple Titles but not sure if thats the best way to go, since only 1 of my DVD players has a Title button on the remote, so my RCA might have difficulty switching to a second Title.
Id also like to use Freeware, I got this far using it.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Many DVD authoring programs allow you do put more than one movie on a single DVD.
The main menu will allow you to select which movie to play, it will play it till the end and return back to main menu.
Chapter points are defined within each movie independently from each other.
Here are some that can do it: neoDVD (cheap), reelDVD (inexpensive), DVDLab, TMPGenc DVD Author.ktnwin - PATIENCE -
ktnwin
Pretty much covered all of the DVD Authoring programs out there that will do what you are asking for
Note: you can also change chapter points
I myself use TMPGEnc DVD Author and must say am very satified and it dosen't cost an arm
Just my 2cents
Help selecting new camcorder
By shredman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Apr 2010, 14:28 -
Selecting the preferred DVD decoder/codec for WMP under Vista x64
By Dark Alpha in forum Software PlayingReplies: 10Last Post: 17th Jan 2009, 22:05 -
help in selecting chapt of different versions on DVD to rip
By willcarson in forum MacReplies: 2Last Post: 16th Jan 2008, 10:05 -
Help selecting MB for encoding
By DennisHagemann in forum ComputerReplies: 1Last Post: 17th Jul 2007, 18:58 -
Need serious HELP on selecting MUSIC
By jimcornetet in forum Newbie / General discussionsReplies: 5Last Post: 15th Jun 2007, 21:52
