Results 1 to 13 of 13
  1. Anonymous
    Guest
    When converting .. say .. using TMPGEnc, will the .mpg file always result in a x2 bigger file ? The reason I'm asking is because a friend of mine encoded a movie and made it .avi .. but its on two 500mb+ files.. and now.. if I want to convert that to a VCD .. I'll end up with like 4 CDs .. any ideas ?
    Proctor
    <font size=-1>[ This Message was edited by: proctor on 2001-09-27 15:43:09 ]</font>
  2. Anonymous
    Guest
    Also ... how can I know the projected file size ? A "sneak preview" of the size that the program estimates will be...
    Feb 2001
    Berlin, Germany
    http://www.vcdhelp.com/vcdtools.htm > bitrate calculators
  4. Anonymous
    Guest
    Not the bidrate.. I wanted to MB estimate...
    Feb 2001
    Berlin, Germany
    Well, the filesize depends on the bitrate. For example VCD is 1150+224=1374 kbps, so 1minute is about 10 MB. Let's say you make a XVCD 2524+224=2748, so 1 minute is about 20 MB.
    I am not really sure, what you mean. FitCD shows you the absolute filesize in KB as well.Hope that helps.
    Jan 2001
    Vancouver/Portland
    FitCD isn't too accurate for the past week I been using it. When I actually encode and burn the CD, the CDR Time comes to +plus ~5 seconds to what it said in FitCD... But it's the most accurate program available, so you can't complain much. =|
  7. Anonymous
    Guest
    How do you figure that "XVCD 2524+224=2748" is about 20mb ?
    Feb 2001
    Berlin, Germany
    As I said, use a bitrate calculator. And I prefer FitCD.
    Probably you noticed, that 2748 kbps is double as much as 1374 kbps. You guess right, the expected filesize is also double as large.
    Jan 2001
    Vancouver/Portland
    What a coincidence, a new version of FitCD came out recently! It has a nice colorful, yet very similar GUI =)
    Changes: v0.9.3: Sept, 25th 2001
    - some changes in bitrate- & block analysis
    - added MPEG1-muxing support for e.g. (X)VCD
    - added NTSC-support
    - small bugfixes
    <font size=-1>[ This Message was edited by: Jeomite on 2001-09-27 15:10:42 ]</font>
  10. Anonymous
    Guest
    How do I know what bidrate the original .avi that I have is ?
    Feb 2001
    Berlin, Germany
    A bit is a bit, doesn't matter which kind of file it is.
    The difference is, that you can fit up to 807 MB on a 80min (S)VCD, but 700 MB on a 80min DivX (data-CD).
    Use a bitrate calculator. Man do it, do it now.
  12. Anonymous
    Guest
    Ok, I d/led FitCD but now I find myself ignorant to the way I need to use it ...
    Feb 2001
    Berlin, Germany
    http://members.tripod.de/fitcd/ReadMe.txt
    If you post an example in the next few minutes, maybe I can help you.
