What format should I use to record video for a max quality on a HDTV-ready TV (1080i max), if my miniDV specs are 720x480? Is there a way to get loseless on a cdr (not DVD)? Note that even if I can only fit minimal time on a single cd I would still consider it. No DVD burner just yet.
The best standards compliant format is SVCD. I use them on a 42" 16:9 TV with good success.
That what I was thinking. Here is my view of the process, tell me if I am missing anything:
1) 16:9 Wide format camera setting
2) Capture in DV format using Video Studio 7 (loseless quality capture)
MPEG-2 compression (using TMGEmpeg)
3) Start SVCD project and just add MPEG-2 project to it (already edited, titled)
4) Burn and enjoy
Now, couple little questions:
a) Which codec is best to go to MPEG-2?
b) If I deinterlace the video after capture and before compression - do I lose any quality? My TV is progressive scan (digital), could I have problems there?
c) Would RCA or Component hook up between DVD and TV make a difference for quality playing back SVCD?
d) Is SVCD going to be the loseless quality copy of miniDV? -
no. depending on your settings, you can get pretty good results but it is not loseless.Originally Posted by andruxaHis name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
The only way to get it to yur TV lossless is by playing the tape directly to the TV. Even DVD looses qualityIs SVCD going to be the loseless quality copy of miniDV?
Is the feature Internet stream ready same as Wi-Fi ready on the Blu-ray DVD
By coody in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Nov 2010, 21:09 -
A Few Questions About Older Sony "HD-ready" CRTs, I-Link, etc.
By Seeker47 in forum DVB / IPTVReplies: 5Last Post: 7th Jun 2010, 01:51 -
HDTV Ready help
By thejollypostman in forum DVB / IPTVReplies: 1Last Post: 27th May 2009, 16:07 -
HDTV Ready Help
By thejollypostman in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 14:39 -
HD DVD player with HD-ready HDTV component only
By hbecs024 in forum DVB / IPTVReplies: 14Last Post: 24th Jun 2007, 01:55
