I am trying to backup Merlin (about 7.6GB size after ripping it with dvdshrink) onto two discs using the "copy entire DVD". DVDFab ver 0.16.1 splits the two discs with about 7.3GB for disc 1 and about 200mb for disc two. Splitting the movie only works fine (but you lose the menu)
Version 0.15.1 splits it with about 3.3GB disc1 and about 3.8gb disc2. I have been using 0.15.1 for about a month or so and was successful in backing up multiple DVDs without a problem. Merlin however seems to choke both versions.
Any ideas why this might be!
Thanks,
I had similar problem with DVDFab 0.15.3,0.16.0, and 0.16.1. It was quitting on me in the middle of the "Processing Files".
DVDFab is tring hard to fix this issue. Hopefully we will have new version soon with fixes.
BTW: Where can I get 0.15.1? I can't find it on the DVDFab's website.
Hope asking for a freeware is not warez! I would like to give a try. -
mrbass wrote on 7.16.03
Thanks so much for releasing one last freeware version. I was born in Germany but have to say the current laws suck there and I'd do the same thing if I were in your shoes.
* Version: 0.17.0
* Date : 11.07.2003
*** New
Italian and croatian translation added.
There are no nag screens anymore.
*** Changes
*** Bug fixes
Copy complete DVD: Fixed bug if no VIDEO_TS.VOB was available.
Official homepage will be no more but I'm sure you can also download it from http://www.doom9.org or http://www.mrbass.org/dvdfab
_________________
www.mrbass.org DVDShrink | DVDFAB | DVD2DVD-R | InstantCopy7 | DVD2SVCD guides
I found Merlin to compress surprisingly well with several programs. I suggest you try it. I know it is a large movie but must be encoded wastefully to start with.
DVDFab 7 and subtitle problem
By suirauqa in forum DVD RippingReplies: 1Last Post: 28th Apr 2010, 13:21 -
There might be a problem ripping Transformers in Canada, with DVDFAb
By harrisonford in forum DVD RippingReplies: 1Last Post: 20th Oct 2009, 11:45 -
DVDFab HD Decryptor File Splitting
By Nitro89 in forum DVD RippingReplies: 5Last Post: 10th Feb 2008, 13:48 -
problem with DVDFab Decrypter
By cmonzon in forum DVD RippingReplies: 1Last Post: 4th Jul 2007, 20:18 -
DVDFab Inquiry/Problem
By americasboytoy in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2007, 13:05
