I have this dvd wich is home made, and it isn't divided in chapters. suppose i wanted to split the movie in chapters and make a new dvd out of it, how would i do then?![]()
Results 1 to 11 of 11
What software do you have available.
Do you still have the movie on your computer or is it only on the DVD now?
DVD Studio Pro can add chapters and I'm pretty sure iMovie 3 can put chapters in that iDVD 3 will recognize.
Give us a little more information and we should be able to help you out.
jbcandkcI'm just sitting here watching the wheels go round and round.
-John Lennon -
Well i don't actually have the movie yet, i'm going to record a movie from the tv, and a friend will put it on a dvd for me. But he said it will be without chapters, menues and other fancy stuff. So i thought when i get the dvd from him, i might be able to add some chapters myself.
I think i will get the dvd from him this weekend. I was just throwing out this question in advance, so that i will know what to do when i get the dvd.
These are my tools:
0SEx 0.0110a1
forty-two
dvd2onex110
DVDBackup 1.3
ffmpegX0.0.7c
FireStarter_FX-1.0b4
Gumby Beta 2
iMovie
iVCD Folder
MissingMediaBurner
Mpeg Splitter
mpgtx-14-beta-4_GUI
Sizzle 0.1
Transcoder 1.0
VCD Builder 1.1.1
vcdtoolsX
(I think i have dvdstudio pro too, but i hardly ever use it cause i think it's to hard for me).
I would be very glad for any suggestions on this problem (thanks in advance). -
I would probably try to use OSEx to rip a single muxed mpeg file from the dvd, then I'd use Sizzle to author, providing the custom chapter times in the Other tab. These are the times I use get a chapter every 10 minutes for an hour and a half.
0:00:00.00,0:10:00.00,0:20:00.00,0:30:00.00,0:40:0 0.00,0:50:00.00,1:00:00.00,1:10:00.00,1:20:00.00,1 :30:00.00 -
Ok, thanx!Originally Posted by llee782
I'm going to try that as soon as i get the dvd.
Ive done that method. it works well.
if you have problems, you know where to post. -
I did this, but the dvd had only 2 chapters.0:00:00.00,0:10:00.00,0:20:00.00,0:30:00.00,0:40:0 0.00,0:50:00.00,1:00:00.00,1:10:00.00,1:20:00.00,1 :30:00.00
Any suggestions?? -
Use Sizzle to author but you can't author with a mpeg you have to split the video and the audio. You can join those two chapters using MMT and then chapter in sizzle but remember they have to be demuxed.
Hi!!Originally Posted by Vintageman
I gave sizzle one "m2v file" and one "mp2 file" but still this only gives me two chapters.
I did also try to give sizzle a vob, but the result was the same.
Guestt i'm still stuck. -
Under others in Sizzle make sure ( use custom chapter times) is checked in.Then just copy this and paste it in the box---0:00:00.00,0:00:20.00,0:05:00.00,0:10:00.00,0:15:0 0.00,0:20:00.00,0:25:00.00,0:30:00.00,0:35:00.00,0 :40:00.00,0:45:00.00,0:50:00.00,0:55:00.00,1:00:00 .00,1:05:00.00,1:10:00.00,1:15:00.00,1:20:00.00,1: 25:00.00,1:30:00.00-- it will give you 5 minute chapters. don't copy the ---
Hi and thanx for your help. This was the best try so far, it gave me at least four chapters. very strange. There should be 20 chapters, but there were only four.Originally Posted by Vintageman
wonder what the problem could be...?
How to make chapters with a mkv file?
By neworldman in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 18:18 -
DVD with chapters already I only want to make a menu while retaining all...
By dbbarney in forum Authoring (DVD)Replies: 6Last Post: 4th Oct 2010, 13:05 -
how to make 3 vob files into a DVD with chapters
By c1steady in forum Authoring (DVD)Replies: 8Last Post: 3rd Oct 2009, 06:46 -
FAVC - How to make chapters instead of titles ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2008, 14:03 -
How to make 'chapters' on an audio CD
By UmmAddan in forum Newbie / General discussionsReplies: 15Last Post: 4th Jun 2007, 04:08
