I'm trying to use it to cut a movie in file in half and encode it (from MPEG4 to MPEG2). When I'm at the source screen, where I pick where I want the file to start and end, I noticed it is incredibly slow at some points, it doesn't have that fast & fluid motion if you hold down any of the arrow keys. Instead it goes frame by frame, one at a time. Sometimes it freezes here, unless you give it time. But when everything is set, and I hit start to encode it, the preview screen stays black, and it freezes. I re-DL'ed the program, and restarted, but it keeps happening.
This is on a P4 with 512MB ram. I doubt it's a hardware problem. Does this sound like a problem with the file or with TMPGEnc or with my codecs maybe? I've already encoded a file which is the first half of this same movie.
BTW the movie comes in 3 files, each about an hour long. Would it be better to sew them all together into one file? Or leave them seperate? I intend for them to be put onto DVDs when it's all said and done.
First of all run it through this version of Virtualdub and do a Video Scan for bad frames.
(Scroll down to the Mp3 Freeze version)
http://www.digital-digest.com/dvd/downloads/virtualdub.html
If its a DIV ,I would then extarct the audio and save as a WAV using the resulting WAV as the audio source in TMPGE
https://www.videohelp.com/virtualdubaudio.htm
If the 3 parts are equal size ,I'm not sure why you are cutting it again?
(if for some reason one of the 3 files is still too big,then use the Source Range and Batch encode process which will work better)
If you still want to put all 3 parts together, I would use the append function in Virtualdub and join it in its AVI state then use the source range and Batch encode to Mpeg2."Today is only yesterdays tomorrow"
ScenalyzerLive Freezing
By JoRodd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Mar 2009, 09:36 -
ffmpegX is freezing! Help!
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 12:41 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 00:08 -
Computer Freezing up
By ruknabard in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2007, 17:52 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 11:57
