  1. WMP9 will only play the first 25 secs. or so of most of my MPEG files then it will stop. I know that all of these files are over 10 min each. Is there a fix?
    I tried running my MPEGs through TMPEGEnc and it will only encode the first 25 secs of the file. What can I do to fix WMP9 or my MPEG files?
  2. It sounds like a problem with the MPEG. Go to the tools section and find a program that will correct the MPEG. They will be under the video repair header.
    Manhattan, NY
    I had this problem. But with avi's.
    All I had to do was reload the latest divx and everything cleared up.
    I'm guessing somethin flaked out when WM9 was installed
