I have quicktime pro, but there is no option to export as mpeg-2. I think I have an mpeg-2 encoder extension, but is this for the OSX version? It's the encoder that came with DVD Studio Pro. What would I need to give QT the export capability it needs?
thanks
You need to have either FINAL CUT PRO
or DVD STUDIO PRO installed to receive this added functionality from the MPEG-2 Plug IN
from Apple's Website:
http://www.apple.com/quicktime/products/qt/specifications.htmlCan I create MPEG-2 content with the QuickTime 6 MPEG-2 Playback Component?
No, the QuickTime 6 MPEG-2 Playback Component does not contain an MPEG-2 encoder, therefore encoding or creating MPEG-2 content is not supported. The component is only a decoder, enabling playback of MPEG-2 content. -
If you truly have DVD Studio Pro installed properly, the mpeg2 export option should be in quicktime automatically.Originally Posted by ruggerjvd
To check if you have it or not, go to your Library folder, then quicktime and see which components you have.
one will be mpeg2 playback (if you have that), the other will be an encoder, if you installed it propelry. If not, and you have dvd studio pro, reinstall it. -
I installed DVD Studio pro. Why don't I have the encoder? Is it an OSX/Classic issue?
No. it works in OSX. in fact, i think its an OSX only thing. You running OSX?
What version of DVD studio pro do you have?
whats in the library/quicktime folder?
can you paste it into here
5.1 with stereo won't export to 5.1 WAV in Premiere
By koberulz in forum AudioReplies: 0Last Post: 15th Jan 2012, 13:19 -
Export Functions under MPEG Streamclip
By kannixpert in forum Video ConversionReplies: 0Last Post: 10th Feb 2011, 12:40 -
MPEG Streamclip question: which is better? QT DV or Export to DV?
By Direwolf in forum MacReplies: 8Last Post: 29th Jan 2009, 12:38 -
Export as Mpeg or AVI
By markannab in forum Authoring (DVD)Replies: 2Last Post: 19th Jul 2007, 22:32 -
PROBLEM: Animation Shop Won't Export To Paint Shop Pro 8
By Aaron1927 in forum EditingReplies: 1Last Post: 10th Jul 2007, 10:44
