I have a DVD authored with SF DVDA on my Win98SE system.
I had already burned it succesfully with Nero 5.5.10.20 on my Pioneer 105 (ver. 1.21) on a -RW disc to test and on a Verbatim -R disk, except for the advice that Nero gives on DVDA authored discs (files reallocation).
I was doing another copy on a Princo 4x -R that I bought to test (the shop assistant assured me that they work with the 105).
The burning was at 2x but after about 60% Nero stopped saying "Queueing failed".
It is the first disc that gives me this problem.
Has anyone else experienced this ?
I have the 105 connected on the RAID controller of my Abit KT7-A, as a master and alone. The Nero log says "DMA ?".
Do I have to upgrade the FW on the 105, put the burner on a normal IDE channel or is it something that can happen randomly?
Riccardom
Just to let you know:
I moved the Pioneer 105 from Raid channel to the secondary IDE channel and now everything works well.
Now DMA looks enabled and in the Nero log remains very few messages about queuing.
Also the progress bar that shows the content of recorder buffer is much more stable.
Hope it can be helpful to someone.
Riccardom
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 18:57 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 17:50 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 15:08 -
failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI Spli
By carcrashhearts in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 12:46
