I encoded an AVI file and now I have two files a MPEG and a WAV file
I chose CBR Linear PCM Audio in my project settings as this reduced the total size of the output to fit on a DVD disc. I have SonicMyDVD and also Ulead DVDMovieFactory 2 but I am not sure know what to do with two files as normally only 1 file was produced as a result of this encoding..
Please help as I am now stuck !!
You could Multiplex the two files into one MPEG file using TMPGEnc. Under "File" - "MPEG Tools" - "Simple Multiplex".
Will -
You need to find a copy of SpruceUp or some other authoring app that will accept the m2v and the pcm files. It works great with the corect app. ...... harrymj3
You could add DVD-Lab to that list, it works best with elemental streams.
Will -
Depends on how you created the MPEGs.Originally Posted by [TEA
Are they MPEG 1 or 2?
Are they in VCD or SVCD or DVD format?
Pick the one that best fits.
DVD format would be MPEG2 Program VBR--
Will -
I tried to "multiplex" both a simple and a normal multiplex but I receive an error message "cannot PCM audio something system on sytem" I click add on the right side , select both the mpg and wave file and error occurs
I have tried both MPEG settings in the drop-down list in this screen
I will try the Spruceup program. I was trying to reduce the size of the converted file by reducing the bitrate of the sound.. The movie won't fit otherwise on a standard 4.7gb 120 min DVD media.
Linear Audio Blip on VHS tapes in EP mode (VCR issue)
By robjv1 in forum RestorationReplies: 2Last Post: 10th Sep 2009, 11:19 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 16:46 -
Vob2mpg PCM audio
By schematic2 in forum DVD RippingReplies: 3Last Post: 24th Feb 2009, 12:33 -
PCM audio in MENCODER
By zepperdude in forum AudioReplies: 1Last Post: 16th Oct 2008, 22:56 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
![Send a message via ICQ to [TEA]Towle](images/misc/im_icq.gif)
