Im using WinMPEG converter (avi-dvd option) (i wish i knew what It thought was dvd standard) after file is converted and imported into dvdlab, an error message pops up about 4:3 pulldown and requires another convertion or "pulldown"(btw what is pulldown and why do i need this), is this normal or is there a way to avoid this? the reason being; on two computer all dvd's that I have made work fine... but when put in my shelf dvd player the movie is pushed to the upper left corner leaving a huge blank area on the bottom and right (in this blank area it generaly shows a flickering menu) even though the menu looks fine... can someone suggest a good converter (usualy DIVX or crap off kazaa) Also most movies take about 2-3 hours for conversion, I have a 1.7 celron and a geforce4 I don't think i have a mpeg decodercard, would it help to get one? if so what is a good cheap one that is fast?
THanks
sorry for the multiple question
Results 1 to 1 of 1
New here - Quick questions
By ImportGuyR34 in forum Authoring (DVD)Replies: 6Last Post: 10th Mar 2011, 08:11 -
quick question about the file browser in DVDLab Pro
By YOURCONNEXX in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2010, 18:16 -
DVDLab pro -multiple movies-menu-objects-BTN number mismatch
By sumeshkri in forum Authoring (DVD)Replies: 11Last Post: 15th Jan 2008, 08:48 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 22:32 -
DVDLab - 2 questions (design & connections)
By LynnL in forum Authoring (DVD)Replies: 3Last Post: 23rd May 2007, 09:25
