I deleted some button using "keep old" cuz i only have unregistered version. Somehow when i play using power dvd it works..the button i deleted wasnt accessible..but when start playing it in my pioneer dvd player the button still works so when i play it dvd hangs..Any suggestion why it doesnt do like power dvd does?
Buttons in different groups are used for diferent display modes.
Registered and unregistered versions treat them differently: http://menuedit.dimad.net/advanced.html#all_groups -
I dont like menu edit at all
I deleted the button on armageddon so you could not get to the options where you could select the language... (as had removed them)
But when i put the film in my Dvd player & select the 'Play Movie' button it took you to the language screen & i could not select to play the movie at all.....
So i think that Menuedit sucks big style...
But thats just because of that problem i had with it -
I've been using menu edit for a few weeks now, and other then perhaps a few feature request I've had zero issues with the full registered version. Well other then the silly way he makes you "activate" your machine like Windows XP or something to use the software.
standalone 16:9 recorder
By dnyboy in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th May 2009, 13:37 -
Need Standalone Recommendations
By Thadius856 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th May 2008, 07:52 -
Removing/Hiding Buttons - Menuedit
By _impromptu_ in forum Authoring (DVD)Replies: 6Last Post: 8th Nov 2007, 19:33 -
DVD Recorder Standalone
By ebob in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 11:40 -
Standalone MP with built in codecs?
By nickolasj80 in forum Software PlayingReplies: 1Last Post: 19th May 2007, 15:24
