Do any of the authoring programs do real stills? Not slideshow/montage, but actual stills.
I would like to create a DVD that would have a catalog section. Something similar to a photo web site. Thumbnail menus or step through manually.
Something like what you can do with VCDs.
I have seen mention of using menus as the stills as a work around.
Computers can't play VCD "photo" CDs without DVD player software and there are some DVD players out there that won't play CD/CD-Rs of any format.
Mike
Sure, the question is what do you think is the difference between a still and slideshow? It's really just all in how you author it.
However, for what you described you might actually want to create a series of menus. Each with a subpicture of selectable buttons/hot keys. You can do this with DVD menu studio, and I believe DVD Lab also has this build in.
Basically you could do this with photoshop, but DVD Menu Studio just makes it easier to generate the subpictures. -
The term slideshow covers alot, which is why I added montage. Most of the authoring programs create a MPEG stream of the pictures, not stills.
I was trying to find a way around the menu thing.
Looks like I'll drag out Photoshop (or GIMP) and start batch processing my pics.
This is going to get messy....
Mike
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Recording Fifa Goals from EASPORTWORLD for montage
By Jonoo in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2011, 13:53 -
How to create a nice-looking image montage?
By jeanpave in forum EditingReplies: 2Last Post: 14th Jan 2011, 23:22 -
Montage
By Pumkinhead in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2010, 05:46 -
video montage
By ht0160 in forum EditingReplies: 1Last Post: 21st Jul 2008, 13:16
