Simple question: is there any tool (shareware or not) that will allow to edit each of all AC3 channels and save each of them as a mono wav file?
Sorry if it is a dumb question. I'm new with all of this AC3 thing. Thanks so much)))) I'll be waiting on line for any help to come
Cristian
you can edit ac3 files in terms of cut with vitec or wobble but to edit the audio contained inthem you must covert to wav files first (using besweet for example) , edit , then re-encode
because ac3 is a highly compressed lossy format -- re-encoding will not as good as the original . -
thanks for your answer
Actually I won't re-encode it. I just want to have each channel on a separate mon wav file. Is that possible with some program? I've heard that one of the channels be contain the music track of the file, so I just want to identify which one is it. Any help on this will be much appreciated
use besweet which can save out as 6 wav files ...
soft encode also can do this
AC3 audio editor.
By reboot in forum AudioReplies: 72Last Post: 8th Jun 2017, 11:51 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
