Hello! I bought a Terapin VCD Recorder a year ago. It worked for 3 months and then quit working. I would like to get it fixed for a cheap price. I can ship it to you and send a return label via UPS. Anyways, the problem is, when I power it up, the light just blinks. I get no lcd display or any video display. Can this be easily fixed? Is it worth my time and money? Please e-mail me at benjam138@yahoo.com if you can help. Thanks very much!
i had a video player that used to do that, i had to replace the power supply, try opening it up and looking for a fuse and check if it's blown, there could be more than one fuse, and they should be close to where the power plug is, if the fuse is not blown then the power supply has gone and it could cost you more than what you paid for it, just get a cheap computer and a cd burner and read the guides here etc.
BilalGuns don't kill people, people kill people, guns just make it a lot easier.
DVD Recorders
By Dragoan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Mar 2010, 11:19 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 11:27 -
Can I fix a VCD?
By Haopengyou in forum Authoring (VCD/SVCD)Replies: 6Last Post: 1st Feb 2008, 00:26 -
Sony Recorders (UK)
By pixelism in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Sep 2007, 15:14 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
