i used to encode a while ago, when i used windows 98, and now i have Windows XP Pro, and i would like to know what codecs and everything i need to use TMPGENC and have it working fine. what audio/video codecs do i need? THANKS
I'd be leary of the Nemo codec pack. I've heard a lot of people and experience it my self, where I've had serious issue with my machine using those codecs.
You might want to consider just getting the codecs that you'll need for what you are doing before entrusting your machine to the Nemo stuff.
Do what you think is best. -
i got it mostly working, but when i encode, there is no audio in the file output. Why is this? is there another codec i need to download?
THANKS -
Dude whatever you do stay away from the Nimo Codecpack your only asking for trouble.
All of the filters can be downloaded on there own, from this site and www.doom9.org.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
