I'm using DVDlab (love it) and when I strip out the wav file in virtualdub, it is too large and my movies can't fit on 1 disc. I'm tryin HeadAC3he but can't conver to mp2 and I can't find any .dll file to install to get this to work.
What are my choices when working with original avi files in extracting smaller size audio?
Results 1 to 11 of 11
Have you tried TMPGenc for encoding? I use that to encode, audio and video - it outputs either an PCM or mp2 audio stream.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
d\l besweet from the tools section, extract audio from .avi with vdub as usual to a .wav file then encode with besweet to .mp2 or .ac3 and import as audio asset after encoding the video, to dvd lab
.m2v=video
.mp2 or .ac3=audio
"The software said Win XP or better, so I Installed Linux" -
Thanks, I've heard so much about Besweet but I thought it cost $$$ and am trying to save a few $.
I'll give it a try. -
It was free last time I checked. Download the GUI too. You may still have to download the individual EXE files too (i.e. azid.exe, lame.exe, etc, etc)....Originally Posted by pcostanza
The price of Besweet is $0
A deal like that you can't pass up, plus it truly is a great program!!"The software said Win XP or better, so I Installed Linux" -
From others advice I have besweet and am trying to convert my large wav file to either mp2 or ac3. It says is saved the file but dvdlab says it's corrupt or doesn't seem to be mpeg audio or bad header. So I wonder if I am missing the 'encoder'. I'm a little green here so I'm not sure if I'm missing the dll file or something else to make this work. I've tried changing the extension to mp2 but that didn't help.
Please tell me what I need and where to get it.
Thanks -
If the directory you have besweet in looks like this then you should be fine.
and check this out:
http://www.doom9.org/index.html?/ac3tomp2.htm
if your inputfile is a .wav, just hit the drop down to highhlight .wav so they're visible
check the guides on besweet on this site or at www.doom9.org
Rights
ac3enc.dll
azid.dll
BeSweet.exe
BeSweet.log
BeSweetGUIv0.6b77.exe
changes.txt
DD-Profiles.ini
hip.dll
lame.exe
lame_enc.dll
mp2enc.dll
readme.txt
shibatch.dll
ssrc.exe
ssrc_hp.exe
tooLame.dll
tooLame.exe"The software said Win XP or better, so I Installed Linux" -
So that explains my problem. I'm mising
lame.exe
ssrc.exe
ssrx_hp.exe
toolame.dll
toolame.exe
I have looked for alternate versions of this program but they are all the same. Other than a google search, where might I get these files from.
Mucho thanks for all your time. -
I think if you go to the besweet website:
http://dspguru.doom9.net/
and go to "Stable Version" you'll find what you're looking for, as for lame.exe and toolame.exe D\L them here in the tools section"The software said Win XP or better, so I Installed Linux" -
Originally Posted by fmctm1sw
Yep. Google woks fine for this. I found all of them in minutes if you can't get them elsewhere...
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
