hey guys,
Ok so I want to convert a divx movie to vcd. However this divx movie must have a some bad frames or be corrupted. It plays the whole way through with media player but when trying to do something with it in virtual dub, like save the audio, it will stop where this bad portion lies. I tried using divxfix, however every time I try to run that, It says the file is copy protected. Is there a work around for this copy protection?
Go to http://www.divx-digest.com and get virtualdub program called vdub-mp3-freeze, load the file, go video>check for freezes, when done, go to the file c:\badframes.log and delete those frames in Virtualdub
thanks buzzinhornets... I followed your directions and I do have a big chunk of bad frames... However I looked and can't find how to delete frames... do you or someone else know how to do this using vdub
If you use "vdub-mp3-freeze.exe" it makes a log of the bad frames on drive c
You can then select "Go To" and type the start of the first lot of frames, hit 1 keyframe back. mark start.
Then use "Go To" to go to the end of the first block, hit 1 keyframe forward. mark end
press delete
save, re-scan new save
_________________
___
___
<font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-09-28 18:27:30 ]</font>
Corrupt audio, need help
By madhorror in forum AudioReplies: 5Last Post: 22nd Apr 2012, 22:00 -
video gone corrupt
By beep911 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 13:58 -
corrupt data
By demonwarrior in forum Newbie / General discussionsReplies: 6Last Post: 4th Feb 2009, 08:27 -
corrupt dv-file
By pdehon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Nov 2007, 08:24 -
Corrupt DivX
By exon in forum Newbie / General discussionsReplies: 3Last Post: 23rd Aug 2007, 03:34
