quick question
between Pinnacle Studio 8 and Adobe Premier 6.5 which one does the best DVD conversion from DV video and which one does the best SVCD conversion from DV Video
Results 1 to 13 of 13
neither would be my first or second choice , but i would (in those two) , pick Adobe Premier 6.5
Premier is better.
studio 8 doesnt even come close.
the good thing about studio 8 is that its more friendly and eazy to use.
on the other hand, if you intend to use studio 8 , you CANT frameserve
to ANYTHING, you will have to use the studio 8 encoder, and its my opinion that its not that good, the other option is to save into avi format.
premier has a lot of plugins, and the mpeg encoder it has is better
and you can install a frameserver if you want.
i whould rather frameserve to tmpeg or cce because they give
the best qulity there is.HELL AINT A BAD PLACE TO BE -
BJ_M: what would be ure first/second choice?
Heavensent: so u think uusin premier to capture/edit and then frameserver to tmpg is best way to do SVCD and/or dvd? -
@somjabetween Pinnacle Studio 8 and Adobe Premier 6.5 which one does the best DVD conversion from DV video and which one does the best SVCD conversion from DV Video
Gee, why not ask...If King Kong and Supreman were in a fight, who do you think would win?
Haven't you read the reviews? Did you research at all before asking this question? This is like apples and oranges, two different animals altogeather. They can't be compaired. Jeeze, a $99. program (before rebates) to a $699. Windows or $549. Mac. with no rebates.Geronimo -
i think it is the right way to go.
i have done dv to svcd convertions before, but only a few times
because i dont own a dv camera, the few times i did do it i used my brothers computer and software, he had premier 6.5 and studio 8.
i got the best resolts when frameserving from premier into tmpeg.
just remember that you will NEVER get the original qulity
of your dv tape if you use svcd resolution and bitrate.
if you want to get realy good resolts, you should convert and burn to dvd.
you can get nice resolts with svcd but dont hope for spectacular qulity.
i whould pick premier - you will not be sorry !
its a bit more complicated than studio 8, but its worth it.
and premier is more stable anyway
(just do a serch on studio 8 and you will see its a bit unstable)HELL AINT A BAD PLACE TO BE -
Well, if $ is not an issue, go with Premier 6.5. How much it cost now?
But Studio 8 is much much cheaper. It costs only $15 (with MR) from
Fry's (www.outpost.com) a couple weeks ago. If you only do some simple
editing, you will likely find that it is good enough. I used Studio 7/8
for about a year and am quite happy with it. -
Heavensent: yea i have tried studio 8 and have been having problems with it (doing svcd and getting sync problems etc) ...i know DVD will give me superior quality but for this particular video i am jus looking for "decent" quality.
i would go with either premiere pro or vegas 4 or ulead mediastudio or final cut pro (if you use a mac) ..Originally Posted by somja
premiere and vegas both use the same mpeg encoder (main concept) and can produce very good results fast ...
both can be a bit more than what is required for the basic editing .. thats what ulead is good for - a more basic , but yet very well featured easy to use program ..
scenalyzer or vegas do better job of capture (transfer) of dv than premiere 6.5 but premiere pro is very good .. -
BJ_M: does Vegas 4 have the ability to author to dvd/svcd or will i need to framserve to tmpg or cce?
yes - vegas w/ dvda can author to dvd/svcd , encode 5:1 ac3, encode to dvd and even burn your dvd's (not svcd - but can encode for svcd)Originally Posted by somja
it can also frame serve out if you wish - but its an option, not required. -
Don't you need some additional soft. to author DVD if you have Premiere ? And mpeg2 codec is included or you have to buy it extra ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Premiere doesn't author but comes with the main concept encoder. You can also use other encoders like cce but not free.Originally Posted by donpedro
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 23:01 -
Adobe premier cs3
By m baqar in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 22:55 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53 -
Pinnacle Studio Plus Titanium 10.5 versus Adobe Premiere Elements
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2007, 17:48 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 11:29
