I am a newbie who just started backing up my DVDs onto VCDs, any pointers would be appreciated.
I have tried two methods:
1. a) Use smartripper to copy the DVD movie onto HDD. b) encode to mpg1 using DVDx. C) author and burn VCD using Nero-express.
2. same as above expect – I use DVD2AVI to frameserve the DVD rip, and encode using TMPGEnc with VCD template.
The major difference I have noticed that with the same 50min movie, DVDx encodes in about 2:10hrs, but the TMPGEnc takes 3:30hr to do the same job. (P3-650, 128ram) What the hell is taking so long? What’s the public opinion on the quality and time for the two ripping/encoding methods?
Also as a side note – Has anyone experienced problems authoring and burning VCD using Neroexpress? My copies play well on the standalone DVD player, but not on my PC – not with PowerDVD or windowsmedia.
Originally Posted by Weevis
Also, I had problems with PowerDVD3, but since I switched to PowerDVD4, things work out better.
I use Nero for burning, not Nero Express.. never tried Nero Express because I never had a problem with Nero. I author in DVD-Lab now and burn with Nero.
Hope this helps--
Will -
Have you tried Easy VCD ? (look in the tools section). it does the same steps as your #2 option : Frameserve with DVD2AVI and encode with TMPEnc, but it does everything from rip to encode all in one. You lose some control over filters, but a nice timesaver and decent quality.
-D
How do I fit a DVD on one VCD with DVDx 4.0?
By Xoanon in forum DVD RippingReplies: 5Last Post: 27th Apr 2012, 02:20 -
compare iso image with DVD/CD
By perfection in forum Newbie / General discussionsReplies: 14Last Post: 26th Jun 2011, 12:38 -
Does reauthoring (TMPGEnc DVD Author) re-encode / degrade video quality?
By MheAd in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2010, 05:42 -
TMPGEnc DVD Author - Does it re-encode DVD Video?
By bbanderic in forum Authoring (DVD)Replies: 2Last Post: 21st Oct 2007, 12:58 -
How do JVC combo VHS/DVD recorders compare to M10 or M100?
By DGinnetty in forum DVD & Blu-ray RecordersReplies: 7Last Post: 27th Sep 2007, 12:14
