i have tryed to piece together two files in virtualdub.
But they are of different formats...... e.g MPEG1 and MPEG layer 3?
Is there anyone program that can put these together THEN convert to MPEG2?
If not what is the way round this in VirtualDub. I'm trying to get around tieing up my computer for hours on end converting files!!![]()
Many thanks in advance.....
D
Unfortunatly for VirtualDub the files must be identical..
Here are a few ideas though..
1) Convert both video files to huffyuv ( lossless ) and then peice them together for conversion to mpeg-2
2) Find some way to use AVIsynth since it can load multiple videos as long as they are the same reoslution and frame rate. AVIsynth is not for the faint of heart as it's a scripting language.
Good luck -
so can i convert at a low quaility only to piece these two together then re encode at a higher bit rate for burning........
or does it need to be kept the same all the way through? -
If you convert them at a much lower bitrate for joining so as to considerably deteriorate the quality then the quality is lost for ever no matter how high a bitrate you encode them at later for burning.
so its the same idea when i'm editing with DV or Beta SP at work? what you put in is what you get out!
Cool....
so can you control the quality in Virtualdub? i couldn't see anything to alter it. I guess it just takes your file at whatever quality you have it and pieces them together?
So if this is the case with what you put in is what you get out? then when you use TMPGEnc and you set the bitrate this is pointless if you cannot control the quality?
I'm being stupid ain't i? i have the feeling creeping up on me!!
Sorry for the stupid questions.......
If the bitratesetting affects the quality and size of the file then the quality must be controlable, hence what you put in is what you get out is wrong.....? no?
I'm sure someone can put me straight.........
Sorry again......
P.S all complaints can be sent to 0800 stupid Knob
D -
Originally Posted by drummerduck -
Maybe I'm missing the point: Encode each clip seperately then author (burn) as two clips? Or join them with TMPG after you have encoded them to MPEG2.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Newbie StaxRip problems
By breck in forum Newbie / General discussionsReplies: 4Last Post: 21st Mar 2011, 14:23 -
newbie having problems with SUPER ©
By emb36206 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Nov 2010, 05:04 -
VirtualDub sync problem - Newbie question
By BobAchgill in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2010, 15:58 -
Samsung Camcorder: NEWBIE Questions and Problems
By gsmforum in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 14:32 -
Newbie problems: TS to Mpg conversion
By waehuun in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2008, 16:00
