  1. hello is there any apps.
    who can burn an standard compilant xsvcd...
    Jul 2001
    Brazil
    XSVCD is not standard compliant. Compliant is SVCD or VCD. In this page on blue column in "WHAT IS" => "SVCD" for more information.
    Bye
  3. ok.
    but how should I do to burn my xsvcd movies.
    I use nero but if I turn of the check standrd compliant.
    can only burn 700 mmeg of movie on an 80 min cd.
    but if I make an compilant svcd I can burn 800 megs on an 80 min cd.
    So how should I do to burn my xsvcd with the check standard compilant on...
    Feb 2001
    Berlin, Germany
    Strange.. Even Nero should burn a 800 MB MPEG, compliant or not, on a 80min CD-R. You know, I don't like Nero, so here comes my usual suggestion. Create an image with VCDImager and burn the bin with CDRWin. Or use VCDImagerEasy, that support CDRdao.
  5. ok I should try vcd imager cd-r win...
    Thnx for the tip....
