Hello!
I'm trying to convert a Quicktime MOV exported from iMovie into an MPEG2 file. When I run ffmpegX, the following log is put out and it doesn't complete.
Any suggestions? I'm trying to keep my final output looking as good as possible within the MPEG 2 file format.
Thanks in advance!
-Shawn
Encoding started on Tue Jul 15 13:58:27 EST 2003
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 38981304 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Volumes/Behemoth HD/Rube Goldberg/Mission to Mars MOV.mp2"
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Volumes/Behemoth HD/Rube Goldberg/Mission to Mars MOV.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/Behemoth HD/Rube Goldberg/Mission to Mars MOV.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting generic MPEG2 output profile
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Behemoth HD/Rube Goldberg/Mission to Mars MOV.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 1508000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/Behemoth HD/Rube Goldberg/Mission to Mars MOV.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 1773200
INFO: [mplex] Setting best-guess data rate.
INFO: [mplex] Sectors = 99 Video delay = 82326 Audio delay = 82326
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 239616 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Padding : sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=562980 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 230540 frame=000161 sector=00000602
++ WARN: [mplex] Audio c0: buf= 2677 frame=000225 sector=00000075
++ WARN: [mplex] Padding : sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2145479 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 230940 frame=000688 sector=00002201
++ WARN: [mplex] Audio c0: buf= 2433 frame=000957 sector=00000319
++ WARN: [mplex] Padding : sector=00000060
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2394954 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237591 frame=000759 sector=00002468
++ WARN: [mplex] Audio c0: buf= 4096 frame=001056 sector=00000352
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2644428 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237591 frame=000833 sector=00002733
++ WARN: [mplex] Audio c0: buf= 4096 frame=001161 sector=00000387
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2893903 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237591 frame=000908 sector=00002999
++ WARN: [mplex] Audio c0: buf= 4096 frame=001263 sector=00000421
++ WARN: [mplex] Stream c0: data will arrive too late sent(SCR)=3143377 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 239616 frame=000982 sector=00003264
++ WARN: [mplex] Audio c0: buf= 2079 frame=001368 sector=00000456
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3392851 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237591 frame=001053 sector=00003532
++ WARN: [mplex] Audio c0: buf= 4096 frame=001464 sector=00000488
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3642326 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237591 frame=001122 sector=00003800
++ WARN: [mplex] Audio c0: buf= 4096 frame=001560 sector=00000520
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3891800 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237596 frame=001195 sector=00004066
++ WARN: [mplex] Audio c0: buf= 4096 frame=001662 sector=00000554
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4141274 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237591 frame=001271 sector=00004330
++ WARN: [mplex] Audio c0: buf= 4096 frame=001770 sector=00000590
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4390749 required(DTS)=0
++ WARN: [mplex] Video e0: buf= 237591 frame=001349 sector=00004594
++ WARN: [mplex] Audio c0: buf= 4096 frame=001878 sector=00000626
**ERROR: [mplex] Too many frame drops -exiting
