I connected a standalone dvd player to my pc by using composite rca cables that go into an all-in-wonder video card. I am able to watch dvd's on the computer monitor. But when I try to record it to hard disk, the video is no good (sound is good).
I assume this is some form of copy protection. Is there ripping software that would work under these circumstances, or do they only work with DVD-ROM?
Thanks for any help.
1) you wouldn't be "ripping", you would be "capturing"
2) as thayne pointed out, capturing is analog, so it will never be able to achieve the same quality as ripping, which is purely digital
3) unless your dvd player can disable macrovision, it will not allow you to make analog copies. -
I believe that any capture device that will copy a protected VCR tape will also copy from your DVD player. I could be wrong but I believe that. ........ harrymj3
Newbie with Xbox - what s/w to rip DVD library @ highest sound/pic quality
By Snuker in forum Newbie / General discussionsReplies: 17Last Post: 13th Jan 2011, 12:37 -
newbie want to rip some vhs into DVD
By bambam in forum Capturing and VCRReplies: 5Last Post: 1st Jan 2011, 02:35 -
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 03:09 -
HT - dvd player in the pc or a standalone?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 5Last Post: 6th May 2010, 07:39 -
NEWBIE QUESTION about dark passages in a DVD rip
By pbecks in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 07:50
